TwinTurbo.NET: Nissan 300ZX forum - It couldn't be a bleeding issue, because why would it
Subject It couldn't be a bleeding issue, because why would it
Posted by Quick_Z on April 13, 2010 at 11:03 AM
  This message has been viewed 197 times.
In Reply To you probably need to bleed your clutch (n/m) posted by aliaZ on April 13, 2010 at 10:51 AM
Message suddenly need bleeding right after a new clutch, when the hydraulic line wasn't touched? Could it be that the force of the new springs are too much for the rubber part of the line, so it would require braided stainless steel lines straight from master cylinder to slave cylinder? How do others with stiffer clutches deal with this issue? This can't be a new problem? I've heard the clutch trave DOES have adjustments, but how do you adjust it? I just think the maximum travel needs to be increased, otherwise I see stainless steel braided lines as the only other solution. I'd like to hear if anyone who has has this problem, was able to resolve it.
